Serial com issue in application versus source code
I have a test set-up with two serial devices that I communicate using Labview 2011 via a USB hub. I get no errors when I am running the source code. But, when I create an application and run it on a different PC, one of the serial devices freeze up, without generating any error.
Any thoughts on why it could be happening?
(3,084 Views)
wrong (outdated) Virtual COM Port driver on the target.  or the driver does not support the OS?
"Should be" isn't "Is" -Jay
(3,076 Views)
Both running on Windows 7. The executable is running on a newer PC. I have reduced my sampling time and put a 1ms delay between write and read. Running it tonight. Let's see what happens.
(3,073 Views)
If that don't work we can dig into the VCP-  I fought enough battles there!  post which chipset (Prolific, Si Labs, FTDI...) and show us the windows driver setup
(3,068 Views)
