Serial VI's functioning using VISTA
Hi Everybody,
Serial VI's of Labview 6.1 using on Windows XP are fine but using them on Operating System Windows VISTA is a problem. Rest LV6.1 functionality is fine.
I used USB-RS232 converter to communicate to external device where LV6.1 was loaded on XP. I select COM port assigned number at VISA Resource Name for VISA Serial function Block. The COM Port number was selected from Device Manager which recognises my USB-RS232 converter after I connect to one of the USB port of PC which was loaded with XP. The COM & LPT Port functionality in Device Manager provides the COM port number for example COM7 or COM9 etc. Select this COM port number and Labview communicates like the regular RS232 serial Port.
Above functionality is working fine with Windows XP, but windows VISTA Home Premium doesn't works. I am unable to select the COM port number at VISA Resource Name from VISA Serial function block. This selection of VISA  resource name gets freezes. How to make VISA Serial to work? Is it a problem of Operating System VISTA ?
(2,590 Views)
(2,577 Views)
