Serial Slash Code concatenation
Yes, you really need to understand how the Number to Hexidecimal String works. The result is not at all the same as a string set for hex display.
Message 21 of 23
(1,073 Views)
Got it now.  And I'll be eating a little crow for lunch today.
Message 22 of 23
(1,054 Views)
If can be any comfort for you. You are not the first doing this kind of mistake;). Then I am working with with a unknown/new instrument. I have made it a habit to always make my test program so close up to data sheet a possible. If it specify bytes I send bytes, and if they are documented in hex I use that format. Later then I know the protocol basics I can change the format. I have wasted some hours by dumb errors. Like be 100 percent sure a string is set to hex display then it is not sigh!
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 23 of 23
(1,048 Views)
