Serial Port with LabView
I have interfaced some of the USB ports but they provide serial conversion with them. that is when USB device is connected it creates a new Com Port. Then you can use standard VISA vis. Probably you may get some of these drives.
Labview user
Message 11 of 23
(2,794 Views)
If you want to use a color box, then just scale the incoming intensity to match full scale on the color box.
Message 12 of 23
(2,789 Views)
hello Aojha,
How can I do that? But I dont want to put LEDs on the GUI. I want to put a kind of boxes that can change the intensity from 0 to 255
Message 13 of 23
(2,788 Views)
Aojha: how do I set up the VISA part? Do you have any schematics that I can follow?
I am new on this software... Sorry
Message 14 of 23
(2,787 Views)
BillMe, How can I do that? First How can I map the data coming from the USB (COMM1) to the Boxes? Let say, I want like kind of timmer that set up the reading from the Master side every 100uS (that is an example) and put that on the box and then move to the next one...
Message 15 of 23
(2,786 Views)
For USB communication with VISA, you should read this and this.
Message 16 of 23
(2,777 Views)
One way of changing Box color could be to Place an LED on GUI. Customize its appearce and place the box that you want to display. then change the color of LED.
If you could send me screen Shot of Box probably I could do something.
Labview user
Message 17 of 23
(2,773 Views)
BillMe
Thanks I will read it once I have change.
Message 18 of 23
(2,768 Views)
Aojha,
These are the boxes I placed using a LED. I dont know if they can change color depending of the intensity.
Also, thanks for your help 🙂
Message 19 of 23
(2,767 Views)
Accepted by topic author FACH1511
I have attached a vi.
 Simulating your signals. Please tell me if this was your requirement.
Labview user
Message 20 of 23
(2,761 Views)
