Serial+MAX
hi
is it possible tp use visa open, read, write and close vis without the measurement and automation explorer?
if yes, how? i am gettin error -1073807202 if i am trying to open a visa connection.
thnk u.
gokul.
(3,438 Views)
You don't have to install MAX but in order to open a VISA connection, you do have to have VISA installed. The error indicates that it is not. The meaning of the error is:
VISA:  (Hex 0xBFFF009E) A code library required by VISA could not be located or loaded.
(3,428 Views)
Hey Gokul,
Dennis is correct, you'll probably need NI-VISA, and if you are to install NI-VISA, it installs Measurement and Automation Explorer automatically for you.
You can download it at:
Nick D.
(3,401 Views)
Run VISA on a non-Windows platform and you not only can run the open, read, and write without MAX, you cannot even get MAX.
Lynn
(3,395 Views)
