Serial Data Write
Attached is actually my try
Message 11 of 24
(3,177 Views)
@naumanhabib wrote:
See i have tried this formula but not getting frequency of that max peak. Please if you can update my vi in which i get frequency value of that max peak.
Supply some data and the actual VI so we can help debug.  Everything looks like it should work based on the picture, but we can't debug a picture.
Message 12 of 24
(3,169 Views)
Check in this VI i am not getting frequency value of max peak with formula specified (Frequency= f0 + df x Index). In my case peak occurs at -16K so i want to store this value somewhere in numeric/string form.
Message 13 of 24
(3,139 Views)
You are searching for the maximum value in your array.  That is obviously the one that reaches the top of the graph with a value of -54 at -28800.
Why do you think it is at -16,000?
What does a negative frequency even mean to you?
Message 14 of 24
(3,135 Views)
i am very thankful to all of you, my this problem resolved too. I now only want to set a threshold for this peak like when max value occurs greater than -50 then glow some led light and for the rest of values it remain show the other values.
Message 15 of 24
(3,131 Views)
Hi naumanhabib,
So you need a simple comparison like:
IF MaxPeak >= -50 THEN
  LED:=TRUE
ELSE
  LED:=FALSE
ENDIF
or more simple:
LED:= (MaxPeak >= -50)
And you aren't able to create a simple code like that?
Message 16 of 24
(3,123 Views)
Yes i am unable because i don't know where to insert that code. Please if you can update my vi. Thanks a lot
Message 17 of 24
(3,105 Views)
Hi naumanhabib,
So you want to compare the resulting peak value with a constant value - and you don't know where to place that code?
What about wiring the "resulting peak value" to a comparison node?
What about wiring the result of that comparison to your LED indicator?
C'mon…
Message 18 of 24
(3,094 Views)
Yes exactly i want to compare the resulting peak value with a constant value - and i don't know where to place that code. Also then i don't know the way for comparison result to led indicator. Help will be appreciated muchh. Thanks
Message 19 of 24
(3,092 Views)
If you are asking that kind of question then I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
Message 20 of 24
(3,090 Views)
