Serial Connections
I'm converting a C/C++ program into Labview... The program simulates a
rectifier, and CSU... (this bit is unimportant)
Anyway... I'm using a RS232 cable, and I need to simulate a RS485 cable with
it...
In C++, the line I would use to set the DTR would be along the lines of:
->outp(comport+1,(inp(comport+1)&253));
Does any one have any idea how I could set the DTR in Labview?
Is it possible... I've exhasted all other avenues of searching, and got
nothing.
I'm desperate.
Slade Squire
Programmer
Rectifier Technologies Pacific
Melbourne, Australia
SladeSquire@rtp.com.au
(2,935 Views)
In a visa property node select within modem line settings the dtr line and it will happen. Ofcourse you need to write to the serial port via visa then.
succes
greetings from the Netherlands
(2,935 Views)
Slade,
RS-232 electrically swings from +12V to minus -12V... and RS-485 is
actually the physical implementation of an RS-422 signal, which is a
differential signal where each leg swings between +5V and GND (in
opposite directions)...
Anyway, do you actually plan on using resistors and zener diodes to
clamp the Tx signal and the DTR signal to create two output signals that
move between +5V and GND, and then use software to make them move in
opposite directions?
How would you synchronize them, since one uses the internal shift
register of the UART? I guess you could use the RTS and DTR as outputs,
right? But how could you generate the bit clock? With the 1 msec delay
function in LabView you really couldn't hope to get anything more that
4800 baud, right? Though
I doubt you could even get that reliably.
Let me know how it works out...
Bill
p.s. You could use Port I/O vi's under Advanced Functions to write
directly to the port just as you did in the C code.
> it...
> nothing.
> I'm desperate.
> Slade Squire
> Programmer
(2,935 Views)
