Serial Communication
Why can't I communicate serially with another product?
(3,596 Views)
That depends on your application. Can you give some details of your setup and the problems you are seeing?
(3,595 Views)
Hi
I do have the same problem to have a proper communication with my serial device through LabView.
For proper communication i want to insert inter-character delay in the command.
But through LabView i dont know how to do it.
Please help me also. sujit@protoninstruments.com
I'm using LabView 8.0.2
Thanking You in Advance
Sujit Tom JoseSmiley Indifferent
Using LabVIEW 8.0, 8.0.1, 8.2
(3,417 Views)
Hi Sujit,
Can you communicate at all with your device through LabVIEW?  Have you tried any example programs?  Are you getting any types of errors when you run your program?
Thanks!
Adam W
Applications Engineering
(3,378 Views)
Hi Adam,
I've got a solution for giving the Inter Character Delay in the command to written in Serial communication through LaVIEW. I'm attaching the Front Panel and Block Diagram screenshots here.
Thanks for your support and all
Thanku all
Best Regards
(3,355 Views)
