Serial Communication freezes Mac OSX 10.74
I am trying to communicate with a serial device using a USB adapter on a MiniMac OSX 10.7.4. I am using Labview 2011 SP1 and I have installed serial drivers 5.1.1
I have a major issue here (which does not exist with the sam hardware and a PC)
With this decice I need to send commands to the device and then device sends back several line (two to 3 pages) of respond.
The problem is that everytime I send a command to the unit, I do not read the buffer empthy,then the whole MavMini freeses and have no choice other than a cold boot.
Serial communication is the basis of the job I am doing and this nasty bug must be solved before I can go on.
What Can I do to get imediate help?
Any body here has had the same issue?
any hint may help.
Rgards,
Behzad
(2,787 Views)
Is the serial buffer larger enough for this serial port?
Is the amount of data "several lines" or "2 to 3 pages"?  That is a big difference.  And I'm sure 2 to 3 pages of data coming in at once would be enough to overflow a serial buffer.
What device are you trying to communicate with?  Does it require any handshaking, either software or hardware?
(2,780 Views)
What USB to RS-232 adapater are you using? The ones with the FTDI chip seem to work well, while the ones with the Prolific PL2303 chip are quite tricky to use.
Lynn
(2,771 Views)
