Serial Commands
Why did you bother to attach without making any changes. If you had simply done what I had said to do, your problem would have been solved and you could mark the thread as so.
Message 11 of 15
(1,747 Views)
As Dennis said, your conversion from the number to a hex string is wrong.  The function you used converts the number into an ASCII represenation of the number.  So 16 would become "0010".  Those are ASCII characters, not a hexidecimal representation.  What you need to do is change that constant to a U16 and then use Type Cast or a Flatten To String to change the representation of the data into a string.
Message 12 of 15
(1,727 Views)
I'm testing to attach a VI (just crossrulz' snippet)...
No, cannot attach "*.vi" files. Still need to rename to "*.vit"...
Well Dennis, I too can't attach VIs. Still the same problem like several month by now! You can check the history of that problem in this thread...
Message 13 of 15
(1,706 Views)
I can. Using Chrome.
Message 14 of 15
(1,651 Views)
Ok. So that problem seems to be browser related.
But I guess that forum should support more than just Chrome. And that problem exists now for several FF versions and is (or: should be) known to NI&Lithium...
Message 15 of 15
(1,632 Views)
