Serial - ACK command to terminate
I need to communicate (RS232) with an Inficon
controller. I know the command set but each
command needs to be terminated with a 'ACK
command.
This is character 6 in the ASCII set. I don't know
how to enter this character on my serial write
command line. Can anyone help?
Brian
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,247 Views)
Hi Brian
To do this in LV you have to use VISA for the serial communications. There is an attribute that lets you specify the termination
characters etc.
Tim S
> command.
> Thanks
> Brian
> Before you buy.
(4,247 Views)
> > command.
I also had to send serial information to an instrument that required char 3 and char 2
STX and ETX for comms.
The way to achieve this is to select the string with ACK and right click on it and select "\" Codes Display this will send it as
ASCII on the port. So use
Strings >> Concatenate Strings from the Functions Pallete to add you command to the termination char then use Visa function write to
send to to the port.
Hope this helps
Rob Kennedy
A.V.Engineer
Seal R
ocks Victoria Australia
61 03 5952 9333
rob@sealrocksvic.com.au
(4,247 Views)
