Serial 625kbaud Communication Problem
Hello
I would like to use the standard VISA write/read  vi's to support communication with a baudrate up to 625kbaud (no parity, 8bits, no data control). It works
fine with 312kbaud so far but not with any higher baudrate. As interface I am using an express card which supports the desired speed and works fine with
an external terminal program.
What are the maximal baud rates supported from the VISA write/read? Is there any "special" settings which needs to be considered?
Thanks in advance
(2,532 Views)
(2,530 Views)
