Seperate Data from received body
Hi, I am inexperienced with labview and need some help.
I am reading sensor data on labview from a database. The data I am receiving is in json. I want to separate the data so i can manipulate the data and use for other tasks. i.e. draw a graph, other tasks of similar sort
attached is a sample program of part of the code. Please can someone assist.
Thanks in advance
(1,558 Views)
You need to specify the correct data structure.
The modified example uses JSONtext Toolkit for LabVIEW
https://tmesystems.net/
(1,534 Views)
I am using 2015 version of LabVIEW, is it possible to provide a solution compatible with the older versions where I can plot the 'acc' results to a line graph
Sorry for the inconvenience.
(1,485 Views)
Accepted by topic author jephin27
As ZYOng said, the important part is to define a LabVIEW data structure according to the json data.
I do not have the JKI toolkit installed, you have to replace "timestamp" and "dataStored" with timestamps if you need them.
(1,466 Views)
