Separating array of cluster into 2 different arrays
I have an array of 5 cluster elements. Each cluster has 1 string and 1 numeric. I have been trying to separate them into 2, one containing only the string values and the other only numeric values. It can be anything either an array or a cluster. How can I achieve this? I have been trying different methods with build array, insert into array etc. But none of them is giving me the final output that I require. Kindly do help me.
(4,529 Views)
Can you post a screenshot of your array of clusters?
My Channel: https://www.youtube.com/@LV_Lab
(4,518 Views)
Accepted by topic author govindsankar
This may be what you need. Use a For Loop to unbundle your clusters and create the arrays.Array of Clusters to Array.png
Founding (and only) member of AUITA - the Anti UI Thread Association.
(4,515 Views)
Hi Govind,
This is a very basic use of for loops
(4,512 Views)
I hope its very basic and many commented the solution, if you are new to LabVIEW please go through basic online LabVIEW Tutorial and Understand More about structure's and Loops.
(4,461 Views)
