Separate data from Serial
Hello everyone,
I'm using data communications to read two sensor (arduino) and represent the valuees in Labview. I don't know how to separate those measurement from the diferents sensors. I think that it should be easy, but I haven't too much experience with labview.
Thank you
Best Regards,
Jose S.
(6,406 Views)
Hi Jose,
yes, that should be easy! 😄
Two notes:
- don't use BytesAtPort here. Either use a TermChar (as you have configured) or a fixed byte count
- the answer to your question is found in your Arduino sketch: how do you send those values on the Arduino side of the serial communication? You need to read/parse the received string in the same fashion…
(6,391 Views)
The first thing we need to know is what does your data string look like? And then what is it supposed to look like once split.
I expect you can use the scan from string function, or some other string manipulation, depending on what your string is.
Ian
LabVIEW since 2012
(6,389 Views)
Thank you for your response GerdW,
I send the values using "Serial.println(temperature)" (temperature is a double) and actually I can see the values in the box, one second aprox from one sensor, and the next second the other, but I want to representate them in diferent boxes, and I don't know how separate them.
Thank you,
Jose S
(6,381 Views)
Hi Jose,
- send them as Serial.println(temp1, ";", temp2).
- Then you need to read a full line string using a byte count of 99.
- Parse the received string using ScanFromString with a format of "%.;%f;%f"…
(6,377 Views)
I would have used a "spreadsheet string to array" (or whatever it's called these days).  Would that have been Rube-ish?
Edit: I guess actually "spreadsheet string to array" (or whatever it's called these days) would be more scalable?
Bill
CLD
(Mid-Level minion.)
(6,358 Views)
Spreadsheet String To Array (the name has not changed for many, many years) is more scalable.  But for just 2 items, I would use the Scan From String.  Any more than that, then I would go to the Spreadsheet String To Array.  At that point, I would likely be using an array indicator anyways.
(6,349 Views)
