Separate compiled code in a .lvlib
I have a lvlib that is not under a project library. I understand that checking the "separe compiled code from source file" of the lvlib only affects new VIs. Is there a way to apply the setting to exisitng VIs similar to "mark project VIs" of a project library
(3,406 Views)
Not that I am aware of however all you need to do is add the library to a temporary project, set the flag and save the library. Now everything that is there is marked and any new VIs added will also pick up that setting.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,381 Views)
Maybe create a temporary project, mark them in the dialog, then delete the project?
Bill
CLD
(Mid-Level minion.)
(3,380 Views)
Jinx.
Bill
CLD
(Mid-Level minion.)
(3,379 Views)
Or just not even save the project to begin with...
1. Create empty project
2. Add library
3. Mark all as Separate From Compiled
4. Remove library (save the library and its VIs when it is being removed)
5. Close project and don't save
(3,364 Views)
