Sensirion sht7x labview
Michibeck
I would like to try your code but I'm working in LabView 7.1.   Is it possible for you to compile your code in 7.1?
Many Thanks
Message 11 of 85
(5,524 Views)
Try this, i hope it works... Smiley Wink
Message 12 of 85
(5,506 Views)
Thank you for posting your code. I am looking at how you got it to work right now. Thanks a lot.
Message 13 of 85
(5,487 Views)
For the USB DAQ that you used, did you connect a resistor between data and the 5 volts? I run your VI and i changed the ports to reflect my config. and it is timing out.
Message 14 of 85
(5,479 Views)
I use the USB-6008 with an build-in pullup resistor to 5 Volt.
You can also use the internal +5V power supply of the DAQ for the sensor.
Example of connection:
SHTxx                              DAQ
______                          ___________________
GND   |-------------------------|   GND                       |
5V      |-------------------------|  +5V                         |
CLK    |-------------------------| writing digital port 1    |
DATA  |-------------------------| reading digital port 2  |
______|          \ -------------|writing digital port 3    |
                                    |__________________|
Message Edited by MarioLutz on 07-01-2006 03:15 AM
Message 15 of 85
(5,480 Views)
SHTxx                              DAQ
With reference to your diagram,
on port 3: did you just connect a wire to port 2 and then to port 3? Or are you using a diode?
pardon my lack of understanding.
Message 16 of 85
(5,450 Views)
Yes, I simply connect port 2 to port 3. You can do this, because of the build-in pullup-resistor to +5V and the open collector configuration of the DAQ. So it is not important if the SHTxx controls the line or the DAQ-card. But before the SHTxx can control the line you must "release" the line, that means a logical "1" on the writing digital port 3. Controlling the line means pulling to ground on a logical "0" and releasing on logical "1".
The reading port is passive.
For more information look for Open Collector digital I/O in google or wikipedia...
Message 17 of 85
(5,408 Views)
Thanks, I appreciate the help.
Message 18 of 85
(5,400 Views)
I tested the driver on a NI-6221 DAQ card. I was not working. I think there is no open-collector configuration of the I/O.
Now I tested and changed the code. There is only one port for reading and writing the DATA line now and I have a timing option for data transfer if there are problems.
Try out (main.vi) and report functionality please.
Message Edited by MarioLutz on 07-31-2006 02:38 AM
Message 19 of 85
(5,365 Views)
Sorry for three times the same file in my last post !!!
There was a browser or connection problem after submitting the post and I reload the page.
Message 20 of 85
(5,355 Views)
