Sending data through a serial write box (vision processing)
Hi there, I am fairly new to labview and vision assistant. I was wondering if I could get some assistance on a particular problem we are having with our project. The idea is that we will use a webcamera to analyze a continuous loop of images and identify shapes, then send the data through the serial port to a controller which uses the mint motion language. The problem we are having is we cant sind a way to send the data we are getting from particle analysis to the serial port. Is there any way we can do this? I would be eternally grateful for any kind of pointers! 🙂
I will attach the write to box we are using right now as well as the program itself
(2,748 Views)
What you are searching for are the functions "Flatten To String" and "Unflatten from String".
(2,737 Views)
This is exactly the kind of thing we need indeed, thank you very much!
(2,732 Views)
