Sending commands(ASCI characters) via RS-232
Hi, I'm having trouble with sending serial (ASCI characters) commands via RS-232.
I'm using Bluepoint4 uv lamp (Hoenle, co), and I connect Bluepoint4 to PC through a RS-232 to USB connector since our PC does not have RS-232 port.
I have been trying to send command with 2 example codes that I got from this forum, but both of them did not work for me..
The 1st example code is a terminal just like Hyperterminal, and 2nd code is pretty much same with 1st on (from my understanding)..
I don't know where to start... Thank you for reading through..
(1,663 Views)
Most serial communication problems can be solved by watching this video: VIWeek 2020/Proper way to communicate over serial
=== Engineer Ambiguously ===
(1,639 Views)
You just need to concatenate : with your command and carriage return constant as shown belowCapture.PNG
(1,592 Views)
