Sending an external trigger to LabView
Dear all,
I'm quite new to LabView and I hope my question is not answered elsewhere, but I didn't find much.
I have a VI that does something in a loop, will receive an external (TTL) trigger and then breaks the loop. This is not a time-critical step and it doesn't matter whether it takes 10ms or 1s. Is there a (simple) way of implementing this on a PC without additional hardware required?
(3,850 Views)
Accepted by topic author DasTho
Hi Tho,
No.
You need some hardware capable to read a TTL signal…
(3,844 Views)
Well it's possible to use the Parallel Port as an Input/Output Channel but I can't say I have ever tried it.
=== Engineer Ambiguously ===
(3,813 Views)
Hi RTSLVU,
I consider a parallel port as "additional hardware" nowadays…
(No simple office computer had such a port in the last 10 years.)
(3,793 Views)
Thanks for the help!
(3,787 Views)
