Sending Voltage Signal from FPGA
Have you verified with a voltmeter that the DIO voltage into the shutter is changing?  Also, what type of load does the shutter present to the FPGA DIO?  The FPGA DIO outputs are only capable of sinking or sourcing 4mA.  You may need to place an open-collector circuit or FET between the two to help boost your drive capabilities if necessary.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 11 of 12
(1,018 Views)
Alright, I did that testing and it works fine now! Thank you. One question: would I be able to change the voltage level in each DIO on this FPGA? if so, how can I do that?
Message 12 of 12
(1,014 Views)
