Sending Information to webpage
Im trying to write a test that goes out to a webpage and selects a value from a check box and submits it. I used a data socket and I was able to get into the website and read its source file, but as far as being able to select a check box in the frame and submit it im a little stumped. Does anyone have any ideas how to use labview to send information to a website?
(3,118 Views)
Ok never mind i just found the invoke nodes. Im going to assume I can use the put property method to send the check box selection to the page.
(3,109 Views)
Hi
I know that you found some solution for you, but I have an idea that good solution I think is to send some variable values in address for php based web pages.
I think it is a good idea for sending some information for external web server.or has you got other solutions ?
bogdani
(3,101 Views)
Well i dont realy have a good solution to the problem as of right now. What i realy want to see happen is basically
-Press Radio Button 1
-Press Submit
-Press Radion Button 2
-Press Submit
-Press Radio Button 3
-Press Submit
Its been a while since ive done any html and im not all that familiar with php, or cgi
Message Edited by Ix on 04-19-2006 02:44 PM
(3,099 Views)
Hi
You could also do some VI and publish it on web site. Then you will be have full control of this what happen with data on web page..
Some examples
http://zone.ni.com/devzone/conceptd.nsf/webmain/0A81885925C72F5386256802007B9611
and more
http://zone.ni.com/devzone/devzone.nsf/webcategories/4EC7586D87341631862567AC004F0E38
bogdani
(3,089 Views)
