Send variable to Macromedia Flash
Hi
I'm trying to obtain data (voltage) from an accelerometer and want's to pass this information to a ActiveX containter. The containter is a Macromedia Flah game  which should read the voltage to make a "move" inside the flash.
Is it possible ... if so - how do i pass on the voltage/variable to the flashgame ?
Thank you in advance
(3,173 Views)
I am trying to make a very similar VI, mainly to pass some numerical value and then animate it on flash.
Did you find a solution for this?
Anyone???
Fadi
(2,879 Views)
