Send email with SMTP Email from a sender adding the name
I used to use .NET methods to send email programmatically with LabVIEW but recently I had to switch to SMTP Email palette,
It works fine, but I don't know how to add the sender's name.
The Open Handle.vi in the palette has the "from" input, where I can specify the email address.
But I get an error if try to add the name.
With .NET I could set "Name emailaddress@domain.com" and "Name" appears when the email is received.
How can I do the same with the SMTP Email palette?
Max
(2,115 Views)
See the shipping example <LabVIEW>\examples\Data Communication\Protocols\SMTP\Send Email using SMTP Client.vi
Reference: Send Email from LabVIEW via a Secure SMTP Server Such as Gmail
https://tmesystems.net/
(2,073 Views)
Thanks for you reply, but That is not using the palette I was talking about.
Here's the SMTP Email palette that I'm using detail:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/data-communication/protoc...
(2,063 Views)
The example is using the exact same palette.
(2,053 Views)
Yes, this last one is the tool that I'm using.
The previous you posted used .NET.
So the question is still the same: how to add also a name along with the sender's email address?
(2,050 Views)
I think using the SMTP tools provided with LabVIEW, adding a From name cannot be accomplished.  I tried to add custom headers but according to help, the FROM, TO, SUBJECT, all default headers can't be overwritten.  You can add a Reply-to header and the name will be displayed upon clicking reply.
aputman
(2,015 Views)
I think this as well.
I had a look too at the custom headers but the help did not seem to leave any chance for this purpose.
Most programming languages allow the "Name <address>" form for the sender... too bad NI has no way to do this in the official built in SMTP palette.
Max
(2,008 Views)
