05-19-2013 02:35 PM
I wanna know if it 's possible to send a 2D table (type: string) from a server to a client into a shared variable.
Thank you.
05-19-2013 04:15 PM - edited 05-19-2013 04:19 PM
If it is a network published shared variable, both have access. A table is a 2D array of strings. (create a custom control containing a 2D array of strings, then create the variable with datatype "from custom control..." and point to the *.ctl file.)
Is this is not what you are looking for, Please define what you mean by the following three words: "Client", "Server", "Send". Are server and client both LabVIEW based? (I am also a bit confused. Typically the client initiates the connection and the server responds, i.e. the server send is reponsed to a client request.)
