Send a json string to an HTTP in labview
I need to assing values to an HTTP site by sending a json string, I have been trying using the HTTP client PUT vi with no success, does anyone have an easy way of sending a json string to an HTTP site in labview thru the PUT method???
Thank you
(7,369 Views)
What have you tried?
This should work as a basic example:
If you have LabVIEW 2013 or newer, there are built-in VIs for encoding/decoding JSON strings to/from LabVIEW clusters.
(blog)
(7,343 Views)
Can you show what you have tried?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(7,297 Views)
