Send SMS using an ordinary Mobile Phone
please make sure you have changed the string constant VIEW to "code display" before you enter "\r\n" to it. You can change the display style with a right click on the string constant.
Mike
Message 21 of 29
(2,012 Views)
tried it. But unfortunately no changes.
Message 22 of 29
(2,008 Views)
hm, i think now you should start to check the hyper terminal settings. Check which baudrate and other connection data you use and use the same in your LabVIEW program.
Mike
Message 23 of 29
(1,993 Views)
I've added in a 'Bytes at Port' property node before the Visa Read.
Also, I've expanded the Read Buffer indicator.
The 'AT' that you were seeing is the 'echo' of your VIsa Write.
So now when it's run, you should see 'AT' followed by 'OK'.
Message 24 of 29
(1,978 Views)
Excellent.
It's working.
What was the actual mistake?
Checking the operation completly.
Thanks very much.
Message 25 of 29
(1,962 Views)
what about when sending AT+CMGF=1.
Could it dont just by replication of the previous code.
A problem here i found in replication is that i dont receive OK and when the program is run again, i dont get OK for AT.
Message 26 of 29
(1,957 Views)
Update...
All working execpt the last of sending writing Cntrl Z at the end
Message 27 of 29
(1,950 Views)
Accepted by topic author Getwonder
Does this post help, there's a couple of suggestions there?
http://forums.ni.com/t5/LabVIEW/How-do-I-enter-CTRL-C-into-a-string-control-in-LabVIEW/m-p/208314
Obviously, this is for ctrl-c using a value of 3, but try with a value of 26 for ctrl-z and concatenate it into your input string.
Message 28 of 29
(1,940 Views)
Thanks very much to all of you.
The code of <Cntrl> Z was /1A.
My program is running now.
Message 29 of 29
(1,918 Views)
