Send Data to PHP to Add Data to MySQL?
I can't access my MySQL database directly (GoDaddy ;-(( ) so I need to send the data through a PHP script. Has anyone done this yet? I have several ideas on how to accomplish this, but nothing seems efficient.
Any Ideas?
TIA,
Jim
LV7.1
LV8.0
(3,355 Views)
Hi Jim,
what are your ideas? You can use the webbrowser activex component to load the page and fill out the elements.
Hope it helps.
Mike
(3,354 Views)
Soooo... my idea was to use a Data Socket and write the values as part of the URL, but I don't know exactly how it is accomplished. I can read from a PHP page using this method to query data and this works quite well. I am doing more research and have found some good info.
Which way is better Data Socket or Browser Object?
Jim
(3,340 Views)
Hi Jim,
if you can send your data as part of the URL, then i think it´s easier as using the Browser object.
Mike
(3,331 Views)
Well...I got it to work as a URL multiple variable. It seems like a crude way to send data and I can only insert one row at a time, but WTH -- it works ;-))
Thanks for your help!!
Jim
(3,310 Views)
