Sencore color pro USB drive with labview
I have a Sencore color pro which measures lumens, Color temperature, Cx,Cy cordinates.
If I want to measure these values using labview, how am I supposed to integrate this sensor
with labview. It has a USB drive. I need to acquire these values and analyze them.
(3,180 Views)
Hi Yesh,
maybe your sensor is delivered with an API. It can be an ActiveX interface or a dll. If it's a dll, then you can use the "call library interface node".
Mike
(3,153 Views)
HelloYesh,
MikeS81 is correct. Yu can interface with your sensor using either ActiveX or Call Library Function Node.
ActiveX and LabVIEW
https://www.ni.com/en/shop/labview/activex-and-labview.html
An Overview of Accessing DLLs or Shared Libraries from LabVIEW
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGZjCAO&l=en-US#toc1
Andy Chang
(3,128 Views)
