Selection of Menu using button
     I've been working with Labview for two week now and have done several online tutorials and things like that. I need to be able to select the menu using one 'Up'  and one 'Down' Button using graphical cursor.
I have attached my application screenshot here.
If any ready vi exists already similar to my application, please post a link to that vi.
Thank you for any help you can provide.
(2,988 Views)
I'm not quite sure I understand what you're trying to do. Are you trying to move some sort of indicator on the listbox, such as an item symbol?
(2,949 Views)
Hello... 🙂
Do you want to select the item using up/down button...? Is it so...?
Or you want to select an item and jump to predefined location...?
(2,921 Views)
Hi ,
As pointed out by above two users it is not very clear of what you are looking for . But by what i can make out it seems you want to select item using up and down menu . For this you have to use Event Structures . These are the ones which allows user interface to control the program flow as the user interface are called as events . I am attacing one program of menu selection with events. you can work on same grounds to make your application running .
Feel Free to get back to us for any further assitance .
Thanks and Regards,
Pranchal Srivastava,
AE,
National Instruments , India
(2,886 Views)
