Selection of Audio Device in Windows
Hi..
How to select the Audio Device in Windows using ActiveX from LabVIEW....
Im using Windows media player Version9..and LV8....
Sodlb
(3,199 Views)
Hi sodlb-
Please reference the following discussion forum and reply if you still have questions.
Question about Sound Devices
Drew Pierce | District Manager, Central Texas | National Instruments
(3,186 Views)
Hi Drew P,
I have seen the device list in control panel...To change the device we need to change that manually..going to that control Panel>sounds and Devices>
The same thing in the case of media player also...in media player menu>tools>options>device>speaker>properties..
In my application im contolling the media player from Activex..and I want to select the device dynamically from LabVIEW i.e  to select the output device to use in Windows media Player ...Can we do that...?
Sodlb
Message Edited by sodlb on 05-10-2007 01:31 AM
(3,173 Views)
Hi Sodlb-
According to the Windows Media - Audio Outputs section on MSDN (see below), unfortunately you will not be able to choose a different output device via ActiveX.  This is obviously a limitation outside of LabVIEW.
Windows Media Player ActiveX control
"By default, the Player control uses the audio device designated as Default DirectSound Device. The audio output device cannot be changed programmatically."
(3,151 Views)
