Selecting different cases from drop down in front panel
Here's what I had in mind earlier:
Of course you should also architect the VI into a real state machine so a new test can be selected later. Currently, your VI just rolls downhill with fixed test input once the program has started.
If not all files are always available and each file with a certain pattern in a specific folder is a "test", I would list the files ("list folder" limited by a pattern) and place the filenames (without extension or folder path) into a listbox. Now you can change the names and number of test by just adding more files to that folder. Use an event structure to listen for double-clicks on the listbox in order to select a new test, for example. Make it scalable!
Message 11 of 16
(1,683 Views)
@altenbach
What's a better way to read files and how to do it?
Message 12 of 16
(1,681 Views)
Accepted by LiliMcDonald
Here's how to use a listbox that is autopopulated with tests from a certain folder. Now you can add and remove test without changing any code at all! Just add/remove files in that folder. 😄
Again, you need to turn your program into a proper state machine first, of course.
Message 13 of 16
(1,677 Views)
altenbach,
Thank you for your examples, I'll do my best to implement them. I get the basic principle of a state machine, but I haven't really studied it at all. I'll just point out that I'm a labview noob. Once I get done with this little project I'll go back to the basics and start learning more of the fundamentals of labview.
Message 14 of 16
(1,667 Views)
And I'm not sure what a proper state machine is...
Message 15 of 16
(1,613 Views)
State Machines
Message 16 of 16
(1,608 Views)
