Select which File is copied from FTP
Hello
I'm building a small tool that should help an operator copying a lot of different log files to the correct place after a test. Unfortunately one of the files is stored on an FTP drive. As the file name always changes and it might not be the latest one I need a browser for the operator to select the proper file. I know how to copy files from the FTP using the "FTP Get File" VI. However, I need the user to be able to select which file should be copied. The FTP is added as a drive onto the computer but I can't select a path over this route.
Does anyone have an idea?
(2,664 Views)
Hello Slaxx,
Have you tried the path to string function to convert a path to the string address that you want?
I don't know if it works or not.
(2,647 Views)
Hello HoussemeddineSnoussi
Thank you for your help. That was my idea first as well. But the problem is the Path Browser won't even let me select a file on the FTP-Drive.
(2,639 Views)
There is an FTP Put and Get example in the Example Finder under Help >> Find Examples.
(2,622 Views)
