Select vs Case Select
My question maybe a bit stupide but Im not figuring the error.
This simple vi should:
- count any paire number und
- build the sume of every paire number
in a given array. Only the select function should be used and not the case select.
Building the sume ist working but counting is not working.
I ll appreciate any advise.
(2,796 Views)
Accepted by topic author Serikah
you made a small mistake, when the current value is not "paire" you select "0" and then add 1, it doesn't make sense.
what you need to do is add 1 if "paire" or keep the previous number
see this :
on a side note, it make more sense to use i32 if you are dealing with integers.
Epictetus
Antoine Chalons
(2,785 Views)
Thank you.
That was my mistake.
(2,778 Views)
