Select signals breaks legend naming
Not sure how to fix the legend naming problem I am seeing..  The best way to see what is happening is to run the attached example. .  If you turn on all the signals and then turn off Triangle wave, the legend reads
Sine
Square
Sawtooth
DC
DC
There is only one DC signal but because the Triangle signal was turned off and the legend was expanded, it moves DC up in the list but also leaves it where it was, thus having two DC legends...   Any ideas how to fix this?
Mic
(2,567 Views)
You could use a property node. Attached is a modified version of your code. Remember, zero is not a vaild input to the property node. Let me know if you have any questions.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,545 Views)
