10-07-2007 07:22 AM
10-08-2007
10:20 AM
- last edited on
03-03-2025
11:44 AM
by
Content Cleaner
Hi m3nth,
Thanks for contacting National Instruments. Right now, these are the two options that are available. The CompactRIO currently comes with one serial port. If you feel that additional serial ports are a good idea for the CompactRIO, please feel free to make a product suggestion for us by visiting www.ni.com/contact and clicking on the "feedback" link in the lower left under the "Product Feedback" category. We are very receptive to any product suggestions that we receive and will definitely take them into consideration. Thanks for your feedback!
10-08-2007 10:37 AM
10-08-2007
01:08 PM
- last edited on
03-03-2025
11:44 AM
by
Content Cleaner
Hi m3nth,
The link involving using the FPGA and digital modules has been successful in the past with many people and like the tutorial says, a big part with this is converting to voltage using a voltage translator. With respect to the ENET option, the link below can be used to direct you to the products that we have that you may want to try to implement multiple serial ports. I've done some research and it appears that there shouldn't be an issue using the converters with a real-time system. When using the ENET converters, keep in mind that it may cause some more latency in your network as opposed to regular serial transmission. If you have any more questions, please let me know. Thanks!
https://www.ni.com/en-us/shop/category/gpib-serial-and-ethernet.html?productId=118842
10-08-2007
01:21 PM
- last edited on
03-03-2025
11:45 AM
by
Content Cleaner
Check out the following links too:
Can I Use the ENET-232 or ENET-485 in LabVIEW Real-Time?
RS-232 Interface using LabVIEW FPGA module
Bassett
10-08-2007 04:03 PM
