Searching SQL database for selected date
LabVIEW 8.6 Professional with Data Connectivity Toolkit 1.0.2.  SQL database is a flat (non-linked) table on an IBM SQL server.
  I'm using the 'Complete SQL Session.vi' to search for records with a particular date stamp.  This information is used to update tally displays on a factory floor.
The SQL statement for example is:  SELECT * FROM TestResults WHERE Date_Test LIKE '%4/8/2011%';
  If the SQL table column Date_Test was created using the Text Data Type (MS Access), I have no problems.  However, if the same column in a different table was created using the Date/Time Data Type (MS Access), it won't return any records.  I can change the SQL statement to read:  WHERE Date_Test LIKE '%2011%'; It will return all the records for the entire year.
Has anyone run across this problem before, and found a workaround for it?
(3,573 Views)
Greetings b.headley!
Would the following example be of any help in your situation?
DataBase: Gathering Information in a Specific Date/Time Range
http://decibel.ni.com/content/docs/DOC-4932
Michael G
Michael G.
Self-realization: I was thinking of the immortal words of Socrates, who said, "... I drank what?"
(3,557 Views)
Michael,
  Thanks for pointing the app note, unfortunately I'm not able to open the example (written in LV 2009, I have LV 8.6).
  Using the description as a guide, I tried using the 'Complete SQL Session.vi' again, but using the BETWEEN statement instead of the LIKE or comparative statements.  Lo and behold, it worked!
  An example 'working' statement read:
  SELECT * FROM Test_Results WHERE Date_Test BETWEEN '04/13/2011 00:00' AND '04/13/2011 23:59';
  Thanks for the assist - it's truely appreciated!
(3,540 Views)
Was struggling with this issue the past day, this was what I needed. I won't have to pull anymore of my hair out thanks to this post.
(3,460 Views)
