Search in project gives "too many search results. Displaying the first 7 results". Why?
Hello all,
I want to have displayed all results. How can I convince LV?
greets, Dave
Greets, Dave
(3,971 Views)
Hi daveTW,
let us find out about the problem. Which LabVIEW Version you currently using?
Do you use in the Project Explorer -> "Edit" -> "Find Project Items" to search? Hotkey is STRG+F.
A Screenshot of your Searchwindow would be helpful.
(3,946 Views)
Hi dennis,
thank you for replying. I'm sorry for being that unspecific.
I am using LV2010 on Windows7 (32 bit), but that problem also occurred on WinXP.
As you assumed, when pressing Ctrl+F in the explorer window, then typing in the Find- Window a common term, like "create", then the dialog like shown below pops up.
Attached is the project file, if this helps.
greets, Dave
Greets, Dave
(3,931 Views)
Hi dennis,
Ok, before I started this thread I didn't do too much research on this problem, I supposed, there is a quick answer.
After opening another project, this project still came up, so it doesn't seem to be a project- specific problem. So I deleted the LabVIEW.ini (renamed it) and started LabVIEW again. Then the LabVIEW.ini was newly created with default settings. After a search in this project LabVIEW showed all results without complaining.
So, after checking the original LabVIEW.ini (which I was migrating from my earlier LV installations) I found these lines:
FindProjectItems.MaxMRUDepth=0
FindProjectItems.MaxResults=7
FindProjectItems.CaseSensitive=False
FindProjectItems.MatchWholeWord=True
FindProjectItems.RegularExpression=False
The line "FindProjectItems.MaxResults=7" explains the behaviour.
But what did I do to let LV insert this setting?
greets, Dave
Greets, Dave
(3,923 Views)
Hi Dave,
I'm using LabVIEW 2010 and Win7 (32bit) to get your system configuration.
First I created a new project, create a VI called "create" and duplicated it 1021 times. If I search for it I found it without the message.
Second I open your project and search for "create" and found 50 Items but I don't get this window.
Maybe you should launch the National Instruments Updater to keep your LabVIEW actual. There is also a patch available at ni.com. Please try this two Options first and let me know if its help.
"LabVIEW Development System 2010 - Windows7/Server 2003 R2 (32-bit(/XP/Vista/Server 2008 R2 (64-bit) - 2010 f2 (32-bit) Patch"
<http://joule.ni.com/nidu/cds/view/p/id/2182>
(3,918 Views)
Hi Dave,
I'm glad to hear that your problem is solved now. I search for a while about this but don't find any information where you can set this option.
(3,915 Views)
Thank you, dennis
Greets, Dave
(3,906 Views)
