Search and Replace String not working properly
I am using LabVIEW 2013. I am receiving messages from a robot via sockets. Attached is the text file for the message format from the robot. I am trying to search for certain characters in the string (¿®  ), but the search and string function doesn't seem to be finding them, even though I can clearly see it's in the input string. Attached is a snippet VI of my code. According to the LV help, "If the replace string is empty, results string contains input string with search string deleted." So that's why it's in my code. You'll have to copy the text and paste it in there and just take out what you are searching for (in my case: ¿®  ).
If someone could please tell me what I am doing wrong or explain to me why it isn't working like I thought it should, I would greatly appreciate the help!
SM
Message 1 of 23
(6,676 Views)
I don't see where you have those two characters in your text file.
Try attaching your VI with your input string and search string containing the data, and save those values as default before you save your VI and post it.
Message 2 of 23
(6,666 Views)
Hi SteMob,
SearchAndReplace does find your search string - when you set the parameters correctly:
Handling "unusual" chars is made easy by choosing a proper display mode for your strings! 😄
@RavensFan:
It seems you use a "too simple" ASCII code page. The mentioned chars are there right after the first asterisk…
Message 3 of 23
(6,660 Views)
Attached is the updated VI with the values stored.
SM
Message 4 of 23
(6,655 Views)
@GerdW wrote:
@RavensFan:
I clicked on the file and it opened up in another browser window.  I copy and pasted it from there.  Apparently that changed those particular bytes to something else.
That is why I asked for the real data to be saved in the VI.
Message 5 of 23
(6,645 Views)
It worked for me, please see attached image.
Okay, first it didn't work then i copieed text in notepad and it worked.
-There's an extra space after search string, correct it to two spaces and it works.
uday
Message 6 of 23
(6,644 Views)
The problem is your search string contains hex bytes FABE 0000  (two null characters)
Clean it up to FABE.
Set your strings to either \codes or hex display so you can more easily see what odd characters or non-printing characters are there in those strings.
Message 7 of 23
(6,639 Views)
For some reason the format changed slightly between us. Attached is a screenshot of what the string actually is. Mine has spaces  and another weird character instead of rectangles like Gerd's has...
Message 8 of 23
(6,637 Views)
REPLY to: The problem is your search string contains hex bytes FABE 0000  (two null characters)
Raven,
I can't change the search string, that is what is coming off of some other stuff that can't be changed... And my HEX shows BFAE 0000?
SM
Message 9 of 23
(6,627 Views)
Change the search string in your VI, not wherever else.
You are searching for BFAE 0000.  that does not exist in your input string which goes BFAE 2020.  You've got 2 spaces there in your input string right after BFAE, but are looking for 2 null characters.
EDIT:  I scrambled up the hex characters when typing them.  But the heart of the message still applies.
Message 10 of 23
(6,605 Views)
