Search 1D find element in which index
Hi all
  I have a demo want to search in 1D find element in which index,from numeric 1-10 when fill in numeric 3,5,6,7,10 can do it right excepted fill in numeric 1,2,4,8,9.What cause for the issue? Thanks for all prompt reply.
(2,402 Views)
Accepted by topic author Sam.Huang
You are dealing with floating point values, so all equal comparisons are questionable. For example if ampltitude=2, the second peak has a value of 1.99999999999999956000 (if you display all decimal digits!) which is arguably not the same as 2. All Y values are the result of complicated calculations and will typically not fall into place unless you are very lucky.
Also:
  • You don't need any local variables here. Makes no sense.
  • You can stop the loop once the result is -1. No need to spin it an additional ~1000x times.
  • Here's your code using more reasonable techniques (same result!)
(2,388 Views)
Thanks for you,I got it.
(2,327 Views)
