Scrollbar
How do I make the scrollbar move with the text.?
(3,203 Views)
You could try this:
Create a property node for the string indicator.
Select Text.. Scroll position.
Right click on the node and crate a constant larger than your expected # of lines.
Execute this code after the string indicator is updated to reposition to the last line.
(3,203 Views)
Hi there,
I would like to achieve the same thing, as to have the scrollbar to move along while the text is being updated. I read your post about how to achieve it but I still can't get it to work.
Could you please give me further info or post an example?
Thank you
B
Labview 6.1
(2,892 Views)
