Scroll bar bug in Table
I activated the vertical and horizontal scrollbar in a Table.
When I scrolled the wheel of mouse on the Table, LV indicated
"Fatal Internal Error: "panel.cpp" , line 4110 LabVIEW version 8.0"
This error has been always issued by using the wheel button on Table.
Was it reported or known issue?
Thank you.
메시지가 04-15-2007 08:04 PM에 labmaster에 의해 편집되었음
(3,033 Views)
labmaster,
This issue was reported to R&D as CAR ID 3TIH4TET. It was fixed in LabVIEW 8.20. If you find that the problem is still happening in 8.20 please post to let us know. Thanks!
Chris C
(3,006 Views)
I too got the same bug but one of the reason for this bug is when Table is Disabled and when u try to scroll from the table u will get the Fatel error.
(2,679 Views)
You are adding to a 4+ year old thread with no new information and without providing any details (Such as even your LabVIEW version!). Do you think you found a different bug? If so, please attach an example that shows the problem.
There is no need to re-report a known bug.
(2,672 Views)
