Scripting : add error cluster
i'can't find how programaticaly adding an error cluster (control and indicator) using "New VI Object" function :
In vi object class, I can't find anything like "error cluster"
Any Idea ?
Thanks !
V-F
(3,360 Views)
Accepted by topic author ramses64
Those are TypeDef controls and not built-in so you need to use the path input.  You can find them in vi.lib/errclust.llb
(3,350 Views)
thanks for your reply, I had solved the problem by using my a ctl with an error in//out cluster, but your solution is quite smarter !
Thanks for all,
Solved !
V-F
(3,319 Views)
