Scripting - Case Structure
@VUC wrote:
That is how I do my workaround, bet that is not "normal" solution since it is possible to connect these nodes by hand.
I am surprised that NI still haven't found solution for these minor-important things.
Evita
I seem to recall AQ mentioning that adding temp nodes is indeed something that they do in many of their scripts, but that might have just been in reference to making sure wires aren't overly complicated when they are scripting larger VI's.
Jon D
Certified LabVIEW Developer.
Message 11 of 14
(1,680 Views)
Found the thread I remembered, it wasn't AristosQueue, it was ShadesOfGrey (Then DFGrey) and it was about placing wires more exactly.
If anyone is interested
http://forums.ni.com/t5/LabVIEW/Programmatically-creating-a-tunnel-with-LV-scripting/td-p/1830745
Jon D
Message 12 of 14
(1,674 Views)
I agree your question is not easy to understand straight forward.
I uploaded an animated gif. Is that your issue?
If so, click inside the case structure once before routing outside.
If this is not your issue please try to explain again.
Change the way you act, eat, sleep, walk, talk ... and you still are the same person. Even though everybody says you are a different person.
Message 13 of 14
(1,672 Views)
The image the OP posted was the output of his scripting code, and he was asking what he needed to do to have the output changed.
I agree he needs to post the actual scripting VI that he is using as well as the output, since both are of use to answer the question.
Jon D
Message 14 of 14
(1,667 Views)
