Script error when using active x navigate function
I get script errors when using an active x invoke node set to navigate of navigate2 if the URL has .js scripts in it. I attached a simple example.
I've tried changing my PCs default browser with no luck.
(2,485 Views)
I also tried disabling java in the browser but the site I want to navigate to (different site than the example) will not work without running the scripts.
(2,483 Views)
The ActiveX Browser methods do not use your default browser but always the build-in Internet Explorer engine. And as we all know this one is old, obsolete and very unsafe.
Rolf Kalbermatter  My Blog
(2,443 Views)
Hi Rolfk, Thanks for the reply. Do you  know of any work around or alternate way of doing it?
(2,432 Views)
Does anybody know how to read and add data to a webpage that will not open in Explorer because of .js files??
(2,403 Views)
