Scrambled data from LPMS-B sensor with Bluetooth
I am working on a program to live-stream the LPMS-B accelerometer, gyro and magnetometer. (http://www.lp-research.com/9-axis-imu-with-bluetooth-wireless-connectivity/)
So far, I managed to connect the sensor and get data from it. However, the data is very scrambled.
Is there a way to decode this scrambled data, or am I doing something wrong with the data output of the sensor?
Please find attached an image of the scrambled data and the VI I am using
Thank you!
(4,476 Views)
Accepted by topic author Ruben29
From the manual, it looks like data is transmitted as hex so right click on the indicator and select hex display.
(4,455 Views)
Yes, that works! Thank you very much!!Smiley Very Happy
(4,448 Views)
Hello
I am using the same sensor LPMS-B. Did you collect the data from this sensor to Labview?
(2,380 Views)
Hi Kaakourh,
According to the 3rd message the problem was solved. And the second message contains the solution to the problem...
So what exactly is your problem?
Where are you stuck?
Mind to attach your VI?
(2,375 Views)
Hello I am using same IMU sensor. I found example on the company site but i can only see acceleration but I need to see all reading of this sensor. Can you help me to get other reading like orientation and linear acceleration.
(2,305 Views)
This one the file I foundit on the company site.
(2,303 Views)
