Scope Express Vi Bugged?
i am working with Labview 8.5 under Vista. New drivers etc.
Following big problem did arise:
I used the Scope Express VI to read the 2 channels of a NI-PCI-5211. Actually this VI works perfektly if i open the panel and make test measurements. But if i close this VI-panel the settings als on an old status. So eg. changing sample rates or input settings is not possible.
It even came worse: I did creat a new -white- vi just with a new scope express VI. I did open this vi, make all settings as i need it and the test runnings inside this panel are ok (Signals etc is perfect). But if i close this VI it does even not show up an connector for signal etc. It seems not to compile the settings into the express vi. So the Express VI icon is without any connector....
Is this bug known? What to do to fix that? Please help, i wanted to finish my PhD Thesis with the last measurements and everything else is working... but this Express vi not.. .:(
yours
Ulrich
(2,831 Views)
Problem solved 🙂
If you import the scope express vi from 8.2 (i have moved this vi manually via copy and paste out of another 8.2 vi) you get this problem...
Repairing the labview installation solves that issue. i did repeat this 2 times now.
subject closed
(2,785 Views)
