Scan string
Accepted by topic author *E*
Jim
Message 11 of 30
(2,574 Views)
Or, if you didn't really mean that they were numbers...
Jim
Message 12 of 30
(2,572 Views)
Thanks jcarmody this seems to work!
Thanks everyone for yall input also!
Message 13 of 30
(2,566 Views)
One last question
04,05,08,,,,,,2.5,1.3,2.1*E
If i only wanted to display the 2.5 which also will be updating/changing how would i alter what you post inorder to make this work? Also it may not always be in the same position at all times but it would always be after the whole numbers. for example
08,,2.5,1.3,2.1*E
Message 14 of 30
(2,553 Views)
One function will do it.
Jim
Message 15 of 30
(2,541 Views)
Thank you very much!
Message 16 of 30
(2,534 Views)
sorry I thought this was finished but a new issue came up I can not fix.
The example below the 2.5,1.3,2.1 will always come after the whole number.
The numbers before will be randomly generated and a double comma may come before the end of the whole numbers.
Sorry for the confusion but I didn't notice this case until after running the program several times
example
04,05,08,,10,11,,2.5,1.3,2.1*E
need to extract
04
05
08
10
11
I was able to get 04,05,08 with your first example by searching for the first     2 commas.
but as these numbers were randomly generated not all the time the first 2 commas are the end of the the array  of numbers I was trying to get.
here is another example
04,05,08,,,,,11,15,18,2.5,1.3,2.1*E
Need to extract
04
05
08
11
15
18
Message 17 of 30
(2,521 Views)
I used a Match Regular Expression to find the first fractional number because I can't count on the ",," any more.
Jim
Message 18 of 30
(2,497 Views)
Thanks jcarmody you have been really helpful.
Appreciate it!
Message 19 of 30
(2,489 Views)
You're welcome.  Do you understand everything?
Jim
Message 20 of 30
(2,481 Views)
