Scan from string
You guys are the Altenbachs of regEx!
Message 11 of 16
(2,052 Views)
@Darin.K wrote:
You seem to have a lookahead assertion which allows a match of 0 items, basically always true.  If my suspicion is correct, you can eliminate the assertion and make the regex even shorter (\b\w).
When I find myself facing a regex in a loop, I try to see if my old friend Search and Replace can help.
I just tried this and the result that I got was the full name as the initials. Am I missing something?
Update: Never mind. I forgot to check the regular expression option on the search and replace.
(I did have to recreate the VI by hand since snippets aren't working with Firefox.)
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 16
(2,025 Views)
Don't feel bad, I had the same thing happen to me earler with another VI.  I think it was also from Darin.  😉
Message 13 of 16
(2,017 Views)
You're right, \b\w works. Thanks for the tip of replacing the while loop with the search and replace function and the use of the special character $n.
I think the regex used can be simplified to \W*(\w)\w* (but in both cases if you have John Q. the output will be JQ. not eliminating the final dot). To eliminate the final dot \W*(\w)\w*\.* or \W*(\w)[\w\.]* can be used.
Ben64
Message 14 of 16
(2,007 Views)
Here's a Quick Drop plugin to help you use snippets from Firefox.  It fetches the snippet from the URL comment.
Jim
Message 15 of 16
(2,005 Views)
Ha Ha, half of the time I forget to check that before running the first time.  I actually thought of Ray.R and came close to mentioning that fact, but snippets make me lazy about that.  Besides, once you see the before and after of that selection you recognize it pretty quickly.
Hint:  If you see me using that function, rest assured that Regexes are enabled.  Smiley Tongue
Message 16 of 16
(1,991 Views)
