Scan from string in pda
Hello.
I work with LV 7.1, with the I Modul of PDA.
It doesn't work me 'Scan From String'. I have not found any contradiction because the pda doesn't accept it.
Does somebody know which the cause can be? As I can substitute it?
Thank you.
Greta
(3,183 Views)
Hello Greta
The Scan from string function is supported in LV PDA but with some restrictions. The help file for LV PDA tells us:
'The Format Into String function and the Scan From String function do not support changing the numeric separator (such as %#;). The Scan From String function does not support wildcard matches.'
You are changing the numeric separator and this is not supported.
Hope this helps
BelenS
(3,153 Views)
HI BelenS.
Thank you very much.
Greta
(3,144 Views)
